Discussion topic: Black Screen - Sky Q+
This message was authored by: WKRP
Sky Q+ not showing anything other than a black screen. Have checked the following
1) Tv is working
2) HDMI connections secured
3) Powered off the unit, left for 30 secs
4) Powered on the unit - "hello " screen appears - HDMI therefore working
5) Press home at the appropriate moment, amber light goes to green.
6) Remote works, can turn on and off the unit
7) Checked wifi connection and SKY + box has connected to Wireless
😎 Cannot see any issues with cables going to sky dish
What have I missed, TV and Sky were working fine up to about an hour ago so 12.30 ish
Re: Black Screen - Sky Q+
1) Tv is working
hi @WKRP
With the SKY Q box (not to be confused with older SKY + boxes) on (green led) try pressing the following keys on the Q remote in Sequence
Home 1 0 8 0 Home
Avatar for WKRP
Thanks, what does that do ?
Hi @WKRP    Resets the box picture resolution format back to default 1080i.
Avatar for WKRP
thanks, and if that doesn't work, any ideas ?
Avatar for WKRP
Also just to mention, there's no sound from the Sky box, I would have thought I would still have audio if it was just the resolution settings
Avatar for WKRP
That didn't work
Avatar for WKRP
That didn't work i am afraid
hi @WKRP
evn though the TV may be working for other sources etc. - although a long shot try a full power down restart of your TV.
I know you mentioned checked the HDMI connections but if you haven't done so completely take out the HDMI at both ends and re-seat
If that doesn't work II suggest you,, also try a different HDMI input on the TV.
Avatar for WKRP
Thanks, however if I am seeing the "hello" screen would that not surely indicate that the HDMI connection is working ok?
Happy to try it but, I can't see that being an issue
