Discussion topic: Been missing certain channels for months (comedy cental, mtv etc)
This message was authored by: HeartGraffiti
For months ive been getting a no signal meddage for certain channels. All comedy central channels, all MTV channels, all TLC.
All other channels work fine. What can I do to get this sorted?
Re: Been missing certain channels for months (comedy cental, mtv etc)
@HeartGraffiti
A message displaying ”no signal” tends to be from your TV.
A message displaying “no satellite signal” relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check the troubleshooting in this link
If you are connected to a communal dish you’ll need to liaise with you building management company / landlord who will have their approved engineers to contact.
Note: A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
