Discussion topic: Bbc playback issue
Message posted on 05 Feb 2026 04:57 PM
Bbc playback issue
Message posted on 06 Feb 2026 10:52 AM
Re: Bbc playback issue
@xxx wrote:
When I record bbc and try to play it back it doesn't work as there is a delay then it kicks in.
Hi @xxx
Do you see the play bar at the bottom of the screen which appears to be frozen and the box is unresponsive?
After 10 - 15 secs the box will respond to the remote.
This appears to be an issue with some BBC recordings and maybe linked to watch from start. I see the same here.
Message posted on 06 Feb 2026 05:23 PM
@oldfella wrote:
@xxx wrote:
When I record bbc and try to play it back it doesn't work as there is a delay then it kicks in.Hi @xxx
I also see the same on some BBC content
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
