Discussion topic: BLACK BOX ON TV GUIDE ON SCREEN
Message posted on 31 Aug 2023 09:25 PM
I went on to catch up and then back to tv guide and now I have a black box showing over menu? I can still use menu but I have turned sky q off and on again with remote and it won't go. It was fine till I did this
Message posted on 01 Sep 2023 08:58 AM
Re: BLACK BOX ON TV GUIDE ON SCREEN
Hi @Debra1234 Try rebooting your main SKYQ box by turning the power off at the socket for 30 sec then turn back on to reboot?
Message posted on 21 Dec 2024 06:32 AM
I have the same can't get rid of it
Message posted on 21 Dec 2024 06:34 AM
Hiya, wot have you done about it. I've turned my tv etc off but still there so ? Wot do you do next
Message posted on 21 Dec 2024 08:14 AM
Hi @Vickis70 Have you tried the suggestion of rebooting your SKYQ box?
