Discussion topic: BBC channels not working
This message was authored by: Davidxxxxx
Sky Q box seems to be working fine but BBC 1 and 2 are showing, "This channel is currently affected by a problem with your satellite signal".
Going into the 950 and 960 channels and some work and some have this error message.
I have rebooted the box
Any suggestions please
Re: BBC channels not working
You will need to book an engineer visit to  check the dish alignment as it isn't receiving some of the BBC transponders.
Avatar for Davidxxxxx
Thank you
This message was authored by: Invisiblename
Might be an idea to check that the 2 cables that come from your dish haven't come lose at the back of your Shy Q receiver.
I am just another Sky customer!
