3
This discussion topic has been answered Discussion topic: BBC One
This message was authored by: Sky171
BBC One
BBC One is not working on both televisions in separate rooms
Re: BBC One
@Sky171
Any on screen error message?
Re: BBC One
@Sky171
Avatar for Sky171
Re: BBC One
no onscreen message just blank
Re: BBC One
@Sky171
Its always worth starting with a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
