Discussion topic: BBC One is showing BBC NE.
Message posted on 10 Aug 2025 09:54 PM
Q box has BBC One NE HD 101 in EPG
It should be BBC One Lon HD.
The property is in Harlow, CM20 postcode.
Cheers
Message posted on 11 Aug 2025 05:15 AM
Re: BBC One is showing BBC NE.
The regions are based on your postcode. Have you moved recently, particularly from the North East?
Otherwise the first thing to try is a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
