Discussion topic: BBC I player issue. Sky Q box
This message was authored by: Jim327
BBC I player has always functioned well on this sky Q box.
Recently it will not load.
I have carried out all resets and on / off unplugging etc. The main reset was supposed to work within 24 hours. I let it run 26 hours but that has not worked.
Has anyone experienced this problem?
This message was authored by: ozsat
Re: BBC I player issue. Sky Q box
I've had a long running issue in that the pre-programme trailers are announced and then skipped over when I select any programme.
I'd usually skip over the trailers anyway - but they no longer play.
SkyQ Silver bundle (V2 2TB with UHD/HDR + two minis) in Sky region #71 (Oxford) using VirginMedia Gig1 Fibre (1.2Gbps/100Mbps).
