Discussion topic: Audio output from Sky Q Box
Message posted on 25 Feb 2025 12:32 PM
Does anybody know if it's possible to output audio from a Sky Q Box using HDMI and Optical simultaneously? I am trying to devise a way to connect my Bluetooth headphones and soundbar at the same time using an optical to Bluetooth transmitter.
Message posted on 25 Feb 2025 12:37 PM
Re: Audio output from Sky Q Box
@NuevoPortil wrote:Does anybody know if it's possible to output audio from a Sky Q Box using HDMI and Optical simultaneously? I am trying to devise a way to connect my Bluetooth headphones and soundbar at the same time using an optical to Bluetooth transmitter.
hi @NuevoPortil
Yes the optical & HDMI both carry Audio at the same time.
BTW They can be set independently to normal/Dolby Digital (& DD+ for HDMI)
Message posted on 27 Feb 2025 11:13 AM
Thank you for your prompt response. I have invested in a Bluetooth transmitter and it works perfectly using the optical output and USB port on the Sky Q box.
