Discussion topic: Areil
Message posted on 02 Jan 2026 01:02 PM
Areil
Message posted on 02 Jan 2026 01:07 PM
Re: Areil
@gypsy+sister wrote:
I currently have sky q and router .my areil is a big thick cable running through the house do I still need this or do I need a wireless router in place of it thanks I have sky and broadband
SKY Q does need to be attached to the Satellite dish via 2 cables (usually linked as a pair making it like a large single cable)
You would need to switch to a different product called SKY Stream that uses the internet only to no longer need these cables (note this requires sufficient broadband speed)
Message posted on 02 Jan 2026 01:33 PM - last edited: 02 Jan 2026 01:36 PM
Re: Areil
Hi @gypsy+sister Sky Q does not use an aerial, so your post is a little confusing. Do you mean the satellite dish cables, Ethernet cable (direct to the router) or something else?
