7
This discussion topic has been answered Discussion topic: Arc cinema one soundbar
This message was authored by: barbados2009
I have recently been given the arc cinema one sound bar. I have connected to via optical cable to my sky q box. As soon as I switch it on a very loud constant crackling occurs and I have to switch of the sound bar. I may add that I previously for years had a Bose soundbar fitted in the same fashion and it worked without issue for years untill Bose died. Any suggestions would be appreciated.
Avatar for barbados2009
This message was authored by: barbados2009 Answer
Re: Arc cinema one soundbar
Thank you all I have set optical to normal and hey presto it works. Thanks so much for your input. Hive mind
hi @barbados2009
I am struggling to find much info online to confirm it is Dolby Digital  compatible - I note one of the reviews on Amazon also had your problem.
Can you try settingHome - Settings - Setup - Audio Visual
Digital audio output HDMI
to Normal
Hi
yes I have set digital audio output HDMI to normal. Still the same crackling. 😏
Hi
@barbados2009 what is the  optical ouput set to ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
The digital audio output optical is set to Dolby Digital
OOps I meant to change my standard reply (HDMI) to Optical
Glad you have it working - although it won't compare to your Bose
@nigea99 I did wonder if you meant to say optical hence the reason I mentioned 😀
