Discussion topic: Apps
This message was authored by: Abbeyclay1
Apps
How do I get the apps back on sky? I've lost all apps on my sky box such as Netflix, Disney + etc
Re: Apps
@Abbeyclay1 you could try refreshing the apps in the engineers menu
To enter the engineers menu do the follow
press the home button then scroll down to setting and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
scroll down to apps > refresh
It can take upto 24 hours for this to work
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
