Discussion topic: Apps on sky Q keep crashing
Message posted on 16 Jul 2025 09:39 AM
Can anyone help - My sky Q box keeps crashing when I am watching anything via the apps. The programme will lose sound and then freeze with a black screen.
Message posted on 16 Jul 2025 10:13 AM
Re: Apps on sky Q keep crashing
Hi @FayJH
Message posted on 13 Oct 2025 12:42 PM
This worked for me. Not getting black screen anymore. Posted by RAF69
Go to settings on the SkyQ box, select set up, then audio visual, scroll down to Judder reduction for TV apps. It was set to off on my box I turned it on and I've watched two films and six programs without issue.
