Discussion topic: Apps on Sky Q
This message was authored by: Ken+U
Apps on Sky Q
All apps showing as temporarily unavailable. Network is cnnected
This message was authored by: GATK
Re: Apps on Sky Q
I have no app information either.   SKY Q box says it has a connection to my broadband router but no connection to the Internet. My broadband is fine (checked via laptop and speedtest). I reset the network connection and it picked up the same IP Address from the broadband router.  Is there a SKY outage?
Re: Apps on Sky Q
Hi @Ken+U
Try completely resetting you connection.
If you still have no Apps
Have you tried refreshing the Apps in the Hidden menu.
Select Apps 
then highlight Refresh all Apps on this box.
You'll see a message that says, 'Your apps are being refreshed'. This will stay on screen until you press Dismiss to return to normal viewing
It’s recommended waiting at least 5 minutes before doing so.
Refresh Apps can take up to 24 hrs to complete .
