1
This discussion topic has been answered Discussion topic: Apps not working
This message was authored by: Jade228
Apps not working
 Apps are not workiñg on main box or 2mimi boxes
Re: Apps not working
@Jade228
Reboot your Broadband hub then a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
@Jade228
