Discussion topic: Apps not working
This message was authored by: jaclyn2015
Apps not working
None of the apps are working on my sky q box I have turned it off at the mains and I have tried to refresh the app which hasn't worked either
Re: Apps not working
Hi @jaclyn2015
If you still have no Apps try  refreshing the Apps again in the Hidden menu.
Select Apps 
then highlight Refresh all Apps on this box.
You'll see a message that says, 'Your apps are being refreshed'. This will stay on screen until you press Dismiss to return to normal viewing
It’s recommended waiting at least 5 minutes before doing so.
Refresh Apps can take up to 24 hrs to complete .
