5
This discussion topic has been answered Discussion topic: Apps not working on Sky Q unless reset box every time
This message was authored by: JB156
Hi
The Apps thumbnails stopped showing (just blank squares) a few days ago on our Sky Q box then they became v slow to load.  Now the only way to get the Apps to show and load is to rest the Sky box every time we switch it on.  We have also tried the engineers menu App refresh yesterday but haven't seen any improvement.  Anyone have any advice to sort would be much appreciated.
Re: Apps not working on Sky Q unless reset box every time
@JB156 wrote:
Hi we have just followed the reset settings steps and the messages are saying when we click on Apps,  ' because of  a technical issue you are currenlty experiencing a limited service'.  The message on cinema says  we don't have internet connection but when we check on settings it says we are connected.
Any ideas?
Hi @JB156
'Might be worth a Network reset on your Q box.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
@JB156 wrote:
Hi
Hi @JB156
Have you tried a Reset Settings in the Q box hidden menu.
Avatar for JB156
Thanks i'll have a go!
Avatar for JB156
Any ideas?
Any ideas?
Hi @JB156
Avatar for JB156
Thanks seems to be working now, had to reboot Sky Box again.
