Discussion topic: Apps not loading
Message posted on 04 Aug 2026 08:00 PM
Apps not loading
Is anyone else's apps not working? My netlifx, Disney and YouTube won't work at all! All I'm getting is this app won't work
Message posted on 04 Aug 2026 08:07 PM
Re: Apps not loading
@Kayla1996 have you tried rebooting your router
then when thats back up and running
rebootyour main Q box ie
If that doesn't work
you could try refreshing the apps in the engineers menu
To enter the engineers menu do the follow
press the home button then scroll down to setting and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
scroll down to apps > refresh
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
