Discussion topic: Appa
This message was authored by: Lisankeith
Appa
I have a box in the bedroom but the apps have gone missing like Netflix etc anyone know how to get them back on please
Re: Appa
@Lisankeith Have you tried rebooting your mini box ie
if that doesnt work
you could try refreshing the apps in the engineers menu
To enter the engineers menu do the follow
press the home button then scroll down to setting and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
scroll down to apps > refresh
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
