Discussion topic: App won’t load
This message was authored by: Nniiccoollaa
App won’t load
When I’m trying to watch via apps like Netflix, discovery + etc they won’t load or stop working while watching. Internet is working fine and it states no issues with the apps on the sky website. Any ideas how to solve this issue please
Re: App won’t load
What device are you trying to watch them  on ?
Avatar for Nniiccoollaa
Re: App won’t load
Hi, im watching on my TV. Over the last couple of days they won't fully load and either just whirl or log off back to the sky tv Home Screen. I've turned it off at the wall which sorts it out but then the next day it does it again
Re: App won’t load
So is that Sky Q, Sky Glass or Sky Stream ?
Re: App won’t load
Sorry SkyQ
Re: App won’t load
@Nniiccoollaa wrote:
Sorry SkyQ
