Discussion topic: Amber light on sky box
Message posted on 29 Sep 2023 08:02 PM
Sky box showing amber light . So turned off at mains and back on to press home button but not responding. Tried phoning sky but up to 45 min wait time 😞
Message posted on 29 Sep 2023 08:05 PM
Re: Amber light on sky box
Hi @Ki1
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Message posted on 29 Sep 2023 08:16 PM
Hi @oldfella , Thank you for your advice! I now have a green light on my Sky Q box yay but no sky Q light 😞 ! And the tv is on but only at sky home . Won't let me select anything. I have changed remote battery's
Message posted on 29 Sep 2023 08:18 PM - last edited: 29 Sep 2023 08:18 PM
Remote needs to be paired with the box
Message posted on 29 Sep 2023 08:19 PM
Any ideas how I do this?
Message posted on 29 Sep 2023 08:23 PM
@Ki1 wrote:Any ideas how I do this?
I did a "let me google that for you" and it gave the wrong answer 😁😆
hold down 7&9 until the red led flashes a few times. Then hold down 1&3
Message posted on 29 Sep 2023 08:25 PM
Message posted on 29 Sep 2023 08:27 PM
No red flashing happening . I now have green light on and unable to select any channels just a blue screen . Really not what had planned for my Friday night!
No red flashing light happening. All I have is a green light and blue screen. Not what I had planned for my Friday night !
Message posted on 29 Sep 2023 08:36 PM - last edited: 29 Sep 2023 08:37 PM
Hi @Ki1
The flashing is the red led light on the remote.
First make sure that your TV Set is set to the HDMI input connected to your Q box.
I repeat the instructions.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led on the remote flashes and follow onscreen instructions to re- pair.
Message posted on 25 Mar 2024 12:35 PM
Late to this but I have the dreaded Amber light.
I have tried the 7/9 followed by the 1/3 combo. No joy.
I then unplugged, waited 30 seconds, plugged in again. I got a Red light (on the box)for about 10 seconds but it has reverted to Amber.
Any suggestions please?
