Discussion topic: Alternative to using wps button when restarting multi room units?
This message was authored by: Ghost1555
Main skyq built behind media wall. Can I restart multi room units without access to the wps button?
Re: Alternative to using wps button when restarting multi room units?
Hi @Ghost1555
If you are connecting the mini boxes by WiFi to the main Q box (or the Q router if on Sky broadband) then when you carry out a network reset on the mini you have to press the WPS button on the main Q box (or on the Sky Q router if nearer)
Avatar for Ghost1555
Many thanks for your response. Just to be clear so i can use either the WPS on main box or sky router ?
Yes @Ghost1555
If you are on Sky Broadband then you can use it's WPS to connect Q devices.
This of course depends on the distance involved.   More often the main Q box is nearer to the mini however.
Thanks again! My Sky broadband is nearer the mini boxes so I'll give that a go... 🤞👍
