4
This discussion topic has been answered Discussion topic: All channels on same frequency are scrambled
This message was authored by: Paul+Lussier
All channels on the same frequency 11671H are pixelated / unwatchable. Premier sports 1, CNN etc.
How do i fix this? it is currently raining, but its mild (i live in scotland so a rain shower shoudlnt be the sole reason of this)
This message was authored by: nigea99 Answer
Re: All channels on same frequency are scrambled
hi @Paul+Lussier
CNN is on one of the weakest transponders in the UK & Ireland as it is a european wide beam so will be one of the first to pixellate.
Please see the following page that covers a few problems - if you follow the link through and still have problems then you should find a link to book an engineer if you have your own dish
If you have a communal system you may have to contact your building management to deal with the technicians responsible for the system
hi @Paul+Lussier
@Paul+Lussier
A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels (amongst the first to be affected may also include TNT or GB News),
Avatar for Paul+Lussier
Yes TNT is down / pixelated too.
@Paul+Lussier
Check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely either;
▫️a dish misalignment,
▫️a failing LNB (on the arm of the dish),
▫️water getting into the cabling,
▫️very heavy rain
so check the troubleshooting on the link provided by @nigea99
