Discussion topic: Adding prepaid netflix
This message was authored by: mg-monty
I have Netflix included in my package but when I try to access it I am prompted to pick a package with differing fee amounts
Re: Adding prepaid netflix
Avatar for mg-monty
Hi thanks for the swift reply, but comes to the same screen, finish sign up.
Hi @mg-monty
Afraid the Instructions in the Activation link are a bit obscure for Sky Q.
If you already have a Netflix account and are paying Netflix then you need to sign into Netflix on Q using your Existing Netflix details and login.
Avatar for mg-monty
Thank you, I am on Sky Stream though
