Discussion topic: Accessibility on sky q
This message was authored by: Morris1234
My sky q box is stuck on the message accessibility on sky q and won't come off . Neither remote will work to skip or go to settings
Re: Accessibility on sky q
hi @Morris1234
This message (or it's appearance after a reset) seems to have caused a bit of a quirk so try this:
Press & hold 4 & 6 on the remote to set to Infrared only (so must have line of sight of the box)
Hopefully you can then dismiss the message
Then try re-pairing in bluetooth mode with the box by pressing & holding 1 & 3 together
If this does not work try a full remote reset by pressing & holdng 7 & 9 until the red led above the SKY logo button flashes 4 times
Then try the 1&3 to re-pair & pair with the TV
