2
This discussion topic has been answered Discussion topic: Access HBO Max through Sky and BT simultaneous
This message was authored by: jz_rocks
 I currently have Sky and BT registered with the same email address . I access the High-Def ‘BT Sports’ content through App (used to be TNT/Discovery, now HBO max)  -as its a better deal, as I have BT Broadband.
Trouble is I have no way of registering HBOMax through Sky, as it is now effectively picking up my BT account, whenever I go into it.
I think I know what the answer is. I have to go through the rigmarole of registering Sky (and everything associated) with a different account (email). I of course don’t want to have to do this, and would rather find a neater way of doing it. Anyone know of a way?
Avatar for jz_rocks
This message was authored by: jz_rocks Answer
Re: Access HBO Max through Sky and BT simultaneous
Thanks very much! The mySky Activation step seems to have worked well..
This message was authored by: DaveDrizen
If you are saying you bt  HBO max tnt sport login is  the same as you sky login  there should be no problem using both using the  same login, You say the app is picking up your bt account when ever go in to the app, The way round this is log out of app on your Sky  box you should then be presented with a screen with may be QR code and it should say on something like "activate" or "get Sky" as well as log in option Don't login option  as you have found that  logins you in to your bt account but instead use the other option get or activate whatever it says, you should then be presented with a screen to put in your Sky id login just follow instructions to activate the HBO max enterment content. once activated you should  have both access to both HBO max entainment though Sky and as well still be able to have the HBO max TNT sport content. though bt If you still difficult you can ativate your Sky  HBO max entertainment using the my Sky
Avatar for jz_rocks
