Discussion topic: 8 bit
This message was authored by: SmoggyDave
8 bit
Hi I have bought a Samsung UE50CU7100KXXU, i can only get 8 bit ultra hd which doesn't appear to be any different from normal picture, how can I get 20 bit please
Re: 8 bit
I'm not sure what you're expecting?  You need UHD material to get a 'better' picture, i.e. downloaded programmes or some select UHD channels (Sport).  You need a HD sub and an UHD sub too.
Or are you referring to HDR?  What hardware version is your Q box?  How long is your HDMI lead?
I presume you mean 10bit rather than 20?
Avatar for SmoggyDave
Re: 8 bit
Hi I have UHD sub and everything is set up for this. My sky Q box is hardware version 32B206, HDMI lead is approx 3 meters but is an old lead(possibly the problem)
Re: 8 bit
You need a cable rated as 'High Speed' for UHD.  No need to spend more than £10 pounds though.
Re: 8 bit
Almost certainly the lead...
The box is HDR capable.
Re: 8 bit
hi @SmoggyDave
do also check your HDMI Settings on your TV
One Samsung Customer reported needing to set a setting cvalled 'input signal plus' to HDR
There may be others such Deep Color or something similar
Re: 8 bit
@SmoggyDave   Check TV settings menu , should be under General - External device Manager - HDMI UHD Color, then ensure the relevant HDMI input is slected (green dot present).
(Hopefully on your Samsung those settings are still valid as these are from an older model.)
