Discussion topic: 2nd sky box not working
Message posted on 14 Mar 2024 07:07 PM
We had a powe cut, the main sky box came back on, but the 2nd box in a different room in the house will not come back on. It has power but we can't get the light on the box to go green and it won't connect to the TV?
Message posted on 14 Mar 2024 07:47 PM
Re: 2nd sky box not working
Hi @Robin661
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
Try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Failing this Work through the following link
