Discussion topic: 2nd remote not working
Message posted on 12 Mar 2024 02:26 PM
I have today received a new remote control for my Q box now my other one is not working. Can I please get a new 2nd remote for my Q box
Message posted on 12 Mar 2024 03:06 PM
Re: 2nd remote not working
@Davidk14 wrote:I have today received a new remote control for my Q box now my other one is not working. Can I please get a new 2nd remote for my Q box
Hi @Davidk14 That is not something that your fellow customers can do for you. Is this a remote for another box or for the same box. Note you can only pair one voice control remote to a Sky Q box. However you can pair a second remote (pair it first) in IR mode by holding down 4 & 6 to turn off Bluetooth after pairing.
Message posted on 12 Mar 2024 04:40 PM - last edited: 12 Mar 2024 04:41 PM
hi @Davidk14
if you are trying to use 2 remotes with the same box, one must be set to Infrared only - only one can be connected via bluetooth (& use voice commands)
To use both with your TV it is a bit fiddly.
First reset the remote you want to use in IR mode & then pair it with the box & TV
Press & Hold the 7 & 9 until the remote's light (red LED above the SKY logo button) flashes 4 times
Then press 1 & 3 together to go through to re-pair with the box and your TV - make sure it has line of sight of the box as until it is paired it uses Infrared
https://www.sky.com/help/diagnostics/sky-q-remotes/setting-up-remote
Once it is paired with the box (in bluetooth mode) & the TV, then set it to infrared mode by pressing & holding 4 & 6
Then reset & re-pair the one you want to use in bluetooth mode (& don't then press the 4 &6 thus leaving it in bluetooth mode)
Message posted on 20 Jul 2024 06:29 PM
THANK YOU! This was very helpful to me.
Message posted on 14 Jan 2025 02:03 PM
This is the singular most useful advice on sky q remotes. Thank you.
Internet searches say, it can't be done to have 2 remotes paired & working your TV & Sky Q
