Discussion topic: 2TB sky q box
This message was authored by: Jbbangers
2TB sky q box
How do I upgrade to a 2TB sky q box so I can have 2 multi rooms?
Re: 2TB sky q box
hi @Jbbangers
In case you are not aware only the original non UHD 1TB boxes only support 1 active mini
If you need to check then:
If it is 32Cxxx then you do have an older 1TB non-UHD Box which only supports 1 active mini
If it is 32B2xxx then you have a (V3) UHD HDR 1TB or 2TB Box which will support 2  active minis
If you do need to upgrade yopu will need to contact SKY who are likely to charge £99
I believe these are the current methods for contacting Sky. Depending on your reason for making contact some methods are more appropriate than others …
call Customer Services by dialling 150 (free) from either a Sky mobile or a Sky Talk landline.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Note: if your services are restricted due to a missed payment phone contact is unlikely to work.
online help via this link
https://www.sky.com/help
At the end of the help it MAY provide a phone number if it's appropriate.
 Sky Assistant is now available at the top of sky.com/help (or as a chat bubble bottom right if used before) for most service issues and gives you 24/7 help and a quick response. It will provide you with multiple choice options based on your problem and will provide troubleshooting steps to fix any service issues.
Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
