Discussion topic: 1x mini box will not switch on
Message posted on 17 Jul 2023 05:49 PM
Message posted on 17 Jul 2023 06:17 PM
Re: 1x mini box will not switch on
@toni+hayhurst wrote:
We have 4x Mini boxes. All bought at the same time 1 X mini will not switch on We have done all the help , and tips found on line and on website. Still will not switch on The red light comes on for a second and goes off. Can anyone help
I'm sure you may be aware that you haven't bought the minis as all q box are only rented for the duration of your Q subscription.
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Failing this try the Mini recovery procedure in the following link.
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Message posted on 17 Jul 2023 06:36 PM
Tried all of that
Didn't realize the boxes are rented.
Thought we bought them
So if it still doesn't work what do we do
On the website it just says buy another box?
Message posted on 17 Jul 2023 06:41 PM
Tried all of that
Sky have to replace faulty Q boxes free of charge.
Best to contact them directly
