Discussion topic: Sky doorcbell
This message was authored by: Sue19671
Sky doorcbell
Will not connect
Re: Sky doorcbell
Not much to go on from your post.
Assuming it's your doorbell is having issues connecting with your Chime.
Is the Chime showing a blue light?
Some help on positioning of the Chime for the doorbell to keep and maintain a stronger connection;
Keep the Doorbell and Chime within 5m of each other. Go no further than 8m.
Place the Chime out in the open, not behind furniture or in a cupboard.
Try  and create a good line of sight between the two devices. Connection will be stronger if there are as few walls between the devices and avoid having any large furniture in the way.
