Discussion topic: Sky door bell weak
This message was authored by: BYJF
Sky door bell weak
Sky door bell is synced with chime plugged in via Ethernet cable.
Signal is always weak, only two bars so doorbell won't record, the signal is still weak even when the Bell is directly infront of the chime.
does this make it a faulty device?
Re: Sky door bell weak
@BYJF  Have you tried to go into settings>> Device settings >> Devices >> Smart doorbell >> scroll to the bottom to technical information >> click on signal >> and run the test to see how many bars you get for the strength.
