Discussion topic: Set up door camera to new WiFi
Message posted on 21 Aug 2026 08:29 AM
Changed my WiFi and need to connect my sky doorbell camera
Message posted on 21 Aug 2026 09:12 AM
Re: Set up door camera to new WiFi
All you need to do is connect your Chime ethernet cable to your new supplied router.
Would suggest powering off the Chime and doorbell for a few minutes, that should then allow the Chime to reconnect and show a blue static light after a short time.
The doorbell should as before sync to the Chime.
If not try turning off the doorbell for ten minutes using the on/off switch on the rear of yhe doorbell.
Message posted on 21 Aug 2026 09:13 AM
If the doorbell is not syncing, try resyncing it once again to the Chime.
