Discussion topic: Ethernet cable
This message was authored by: tracygrieve30
Ethernet cable
This might be silly but does the chime always have to be connected with the ethernet cable to my router? As when I test the distance it says it fails
Re: Ethernet cable
@tracygrieve30  Yes the chime has to be connected via the ethernet cable at all times.
Avatar for tracygrieve30
Re: Ethernet cable
Thanks, bit of a pain considering my router is in living room and would prefer the chime in the hall
Re: Ethernet cable
You could also use a pair of ethernet powerline adapters, if you have a power socket in your hall plugging an ethernet cable  from the chime into that ethernet adapter and  the other ethernet adapter plugged straight into the router.
