2
This discussion topic has been answered Discussion topic: Doorbell
This message was authored by: Jackie2904
Doorbell
I have my doorbell mounted on my door frame, everything ok biut if the door slams it falls off the back plate, should this happen or should it be more secure?
This message was authored by: mike+simmonds Answer
Re: Doorbell
Hi @Jackie2904
When you push your doorbell on to the white doorbell plate, there should be a definite click and it should be very tricky to remove
Sky customer since 1989.
Sky Q 2TB main box
LG CX6LA from 2020
Re: Doorbell
Hi @Jackie2904
Sky Q 2TB main box
LG CX6LA from 2020
Re: Doorbell
One suggestion @Jackie2904
make sure it's the correct way up with the round button at the bottom
Sky Q 2TB main box
LG CX6LA from 2020
