This discussion topic has been answered Discussion topic: Doorbell charging issues
Message posted on 10 Jul 2026 09:22 PM
Re: Doorbell charging issues
mine charges ok i turn it off plug it in and 24 hours later i am on 100% i had problems at first but it seems ok now
Message posted on 10 Jul 2026 11:44 PM
Posted this over a year ago
sky doorbell was beyond useless
if I were you switch to Ring, 1000% better and cheaper
Message posted on 08 Aug 2026 04:44 PM
Solid yellow lights showing been on for 8 hours and still only showing battery at 16%
Message posted on 08 Aug 2026 04:52 PM
Doorbell was showing battery at 16%
Been on charge for 8 hours and still showing 16%
Solid Yellow light Been showing all that time
Message posted on 08 Aug 2026 04:55 PM
I have just sent message issued
Message posted on 08 Aug 2026 05:15 PM
Can you try turning the doorbell off for ten minutes using the on/off switch at back of doorbell and connect to charging again.
How are you charging?
Assume you are using the charging cable supplied.
That one does work well and should charge in about six to eight hours from around 10% of charge when connected to the Chime USB port.
Message posted on 08 Aug 2026 08:51 PM
Did what you suggested turned doorbell off reconnected twas flashing blue and yellow but gone permanently yellow again after 2 hours
Message posted on 09 Aug 2026 08:24 AM
@Maggie123 If when it does go that solid colour then leaving it for the standard 8 hours to charge then it should be ready for use after that and should refresh on the app reading 100%.
