Discussion topic: roaming problems in france
This message was authored by: ck34
I'm currently in franc and my roaming passport has run out as I have used the 25gb in 1 monthly cycle, what can I do as I need data but do not want to be charged ridiculous amounts of money with being charged £2.50 per 25gb
Re: roaming problems in france
@ck34
It's not £2.50 per 25GB, it's £2.50 per GB.
There is now a fair usage policy. Roaming using Roaming Passport Plus is now limited to 25GBper billing period then it's £2.50per GB. They can also suspend your account.
From Skys own website...
When you roam using our Roaming Passport Plus, we consider that up to 25GB per billing period is a reasonable amount of data to use. If you exceed this amount, we'll assume that you're no longer using data in the way expected of a reasonable customer for periodic travel.
https://www.sky.com/help/articles/sky-mobile-fair-usage-policy.
Avatar for ck34
so what can I do to avoid ridiculous charges, I have travelled quite alot this month and can think this could be the reason, I need data as I have my son with me and he wants to use my phone to facetime and play games, I just dnt want to be charged stupid money I have a £45 roaming spend cap on should I leave that on or will this affect the passport affect
 Hi @ck34  your options are, pay the extra for each gig of data (will be expensive if using a lot), just use free WiFi where available and turn off mobile data or get a local PAYG sim which may have free data attached.
All Opinions Are My Own
