Discussion topic: replacement sim required
Message posted on 04 Feb 2025 04:15 PM
Hi I need a replacement sim as mine is damaged
Message posted on 04 Feb 2025 04:20 PM
Re: replacement sim required
@Chrissy17 You'll need to call Sky for this.
You can call on 150 from a Sky Talk Line or Sky Mobile.
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
