Discussion topic: product cancelled
This message was authored by: Fernanda3
product cancelled
Hi, I signed a contract and it seems it was cancelled. I'd like to understand what happened.
Re: product cancelled
Hi @Fernanda3  this usually happens when you fail Skys second more enhanced credit check. No one here can tell you for sure, only a call to sky will confirm but they won't be able to tell you why you have failed.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
@Fernanda3
For a sim deal it’s just a soft credit check, for a device there’s also an enhanced check. See this link for Skys guidance ~
https://www.sky.com/help/articles/credit-checks-sky-mobile
Be aware that if you keep trying to order the device this could further impact your credit score. If you contact Sky they would be able to confirm that’s the reason your order was cancelled but not why you failed the credit check in the first place as they are not allowed to view your credit record. You would have to sign up to a credit reference agency like Experian or Equifax, which would give you access to your credit record.
Also perhaps check that Sky have the correct spelling of your name.
Any upfront payment you’ve made should be refunded after about 14 days but recent posts suggest it’s taking a bit longer in which case you’ll need to contact Sky to chase it up.
