Discussion topic: poor signal
This message was authored by: Nicola228
poor signal
Poor signal since joining SKY.  Had O2 previously and no issues at all.  Sky sent replacement sim but still no improvement in signal
Re: poor signal
@Nicola228
If you have a poor signal while at home are you able to use wifi calling ?
Re: poor signal
Sky Mobile runs on O2, so effectively they are the same network and the coverage should be identical.
Avatar for Nicola228
Re: poor signal
Yes I can use wifi calling from home
Re: poor signal
I agree. That's without l why I changed as Sky offered a better feal but theis signal is def not as good as O2 for our area
