Discussion topic: piggyback rewards while swapping device
This message was authored by: Dub20
Can I use piggyback rewards be use to swap (upgrade) iPhone 14 to iphone 16 Pro ?
Re: piggyback rewards while swapping device
@Dub20
Yes, you should still be able to use a small amount of data to reduce the cost. It's not a great amount. You have to order the device through an agent and not online.
Offers aren't so great atm - seems like just £10 off for 50GB or £5 off for 25GB.
