Discussion topic: not rgistered on network
This message was authored by: Hoylake82
I am not able to use my mobile phone (not registered on network), my wifes mobile works perfectly
Re: not rgistered on network
@Hoylake82
Will you sim work in your wife's phone, if not you will need to get in touch with Sky support as you might need a replacement as it might be that your one has developed a fault.
