Discussion topic: mobile phone issues
This message was authored by: car32
mobile phone issues
i have changed my mobile provider from 02 to sky, I now can't receive any incoming calls.  I may need to cancel my contract with sky
Re: mobile phone issues
Hi @car32  have you activated your sky sim ? Have you ported a number to sky ? If so when ?
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Avatar for car32
I have inserted the sim card and it all seems to be working but I can't receive incoming calls.  If anyone tries to ring me it says The number you called is not recognised.  what is the issue
Avatar for car32
yes it has all been activated and everything is working except i cannot recieve incoming calls
Is the correct number showing in the settings ?
When did you give Sky the PAC from O2?
