Discussion topic: mms not working after switching
This message was authored by: Annmarie25
mms not working after switching over from vodafone
Re: mms not working after switching
Hi @Annmarie25  have you checked your monthly spend cap isn't set at zero. MMS messages are chargeable so the spend cap needs to be set high enough.
https://www.sky.com/help/articles/sky-mobile-spend-caps
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Avatar for Annmarie25
Level 0 icon
not as zero thanks ,.
everything else is ok calls internet
Hi @Annmarie25  check your APN settings to see if you have a profile for mms.
