1
This discussion topic has been answered Discussion topic: iPhone 18 pro max
This message was authored by: beanturtle
iPhone 18 pro max
Question! I'm upgrading from the iPhone 13 to 18 pro max (when it eventually arrives!). My 13 has a physical sim whilst the 18 will be Esim. Do I just go into my Sky account and activate an esim when I get my new phone or is there other steps I need to take?
Just want to make sure as soon as it gets delivered I can be up and running!
This message was authored by: PandJ2020 Answer
Re: iPhone 18 pro max
iPhone 18's also have physical SIM slot.
If you're looking to keep your phone number then simply move the SIM from old to new phone.
If you activate a new eSIM then it will be in addition to your current dataplan with a new phone number.
