Discussion topic: iPhone 17 pro max freezing
This message was authored by: M-ambrose
My iPhone 17 pro max keep freezing on safari and certain apps it's happening multiple times a day
have done the software updates keep restarting it but now I'm fed up
is anyone else having this issue?
I have seen it a lot in apple support it's like the chip doesn't have enough power
Re: iPhone 17 pro max freezing
Hi @M-ambrose  i woukd take it to an Apple Store to get them to check it out. The sky repair process is below or if you are in the 31 day cooling off period you could call sky and tell them you want to return the device.
https://www.sky.com/help/articles/sky-mobile-phone-or-tablet-repairs
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
It's a fault.
Note the repair process is not quick and you will be without the device for many weeks.  Personally if still within the cooling off period then simply return it.
