Discussion topic: iPhone 16 pro max problem
This message was authored by: kell273d
iPhone 16 pro max turns itself off and then restarts itself
Re: iPhone 16 pro max problem
How old is it?
Avatar for kell273d
Less than two years old
So more than 1 year?  So out of warranty.
In that case the onus is on you to show the fault was there at the time of purchase.
