Discussion topic: iPhone 15 plus charging port
This message was authored by: Amyhughes97
Hi, my charging port on my iPhone seems to be dodgy! If I plug in any charger it doesn't hold it in and it just falls out or stays in for a few seconds chargers then falls out! Bit frustrating charging it
This message was authored by: 2metreToblerone
Re: iPhone 15 plus charging port
If it's not inserting all the way, it sounds like you've probably got some deeply embedded fluff/pocket lint in there, USBC ports are prone to this, they're not tough to clean but if you're not feeling confident about it, it may be better to take it to a professional.
If it IS inserting all the way, and the port feels loose, then it may need replacing. In which case the advice will depend on when and where you got your iPhone.
Avatar for Amyhughes97
oh fab thanks for the reply!
I got my phone from sky online so unsure how that would work
