Discussion topic: iMessage not working after switching
Message posted on 26 Mar 2025 07:41 PM
I switched from o2 to Sky sim.
the PAC was given yesterday.
o2 sim was deactivated today
the text and phone calls are working on the new e-sim
but iMessage and FaceTime are not working, keeps whirring around and won't verify my number. Anyone else had this issue? If so what's the resolution please?
Message posted on 26 Mar 2025 07:50 PM
Re: iMessage not working after switching
Give this a try:
- In Settings, ensure your phone number is showing up in the phone screen under my number
- In Settings > Messages > Send & Receive, untick your number
- In Settings > Facetime, untick your number
- In Settings > Messages, turn off iMessage
- In Settings > Facetime, turn off facetime
- Restart the phone
- In Settings > Messages, turn on iMessage
- In settings > Messages > Send & Receive, tick your number
- In Settings > Facetime, turn on Facetime and then tick your number
IMessage and Facetime should show waiting for activation. You should then get it activated after a few minutes.
Message posted on 26 Mar 2025 07:57 PM
I've tried that- still doesn't work. Does it normally take a long time for sky mobile e-sim to activate iMessage/FaceTime at all?
Message posted on 26 Mar 2025 08:18 PM
I believe it should happen within a few minutes.
Something else to try is to refresh your network settings.
Go Settings > General > Transfer or Reset [Device] > Reset > Reset Network Settings.Then go to Settings - Phone - My Number and change it if it is wrong, then reboot the phone. You will need to set up your Wifi connection again.
Message posted on 03 Jun 2026 07:11 PM
That worked for me, after trying all the other options few times.
